Waterlevel Detector
Triggers when water level has reached a point, then sends an SMS to a given phone number.
Used to warn when water level has reached critical height in a well. Two pumps should take the water away, if both fails, this system should send an SMS to its owner.
  • 1 × Arduino Uno Main processing unit
  • 1 × Adafruit FONA 800 Shield GSM Modem for sending SMS
  • 1 × Arduino Prototyping Shield Just a breakout to attach components and make things more solid
  • 1 × Waterproof(ish) Box Contains the electronics
  • 1 × LM7805 Voltage regulator, used to supply both the Arduino and the FONA 800 chip from the 12 volt supply
