Unlocking your nozzle stepper
A project log for DIY Pick and Place
Cartesian PNP machine using Rails/Carriages for high speed and accurate part placement. Affordable open source pick and place is on the way.
anthonywebbanthony.webb 01/25/2016 at 06:190 Comments
We ran into an issue where our NEMA8 steppers for the nozzle tips were not powerful enough to twist the rubber tube attached to it, even with the 180degree limit enabled. Looks like a couple people have gone with NEMA11 and special (expensive) adapters. We opted to print a little boot for the top of the motor that leaves the shaft to freely rotate inside. Problem solved!
The part is up on thingiverse here http://www.thingiverse.com/thing:1280038
3D files can be downoaded here http://a360.co/23dJGMF
