Jewel Box Servo Meter
Build a meter in a jewel box using a micro-servo driven by a DigiSpark.
A DigiSpark drives a micro-servo to function like a 0 to 5 volt meter. All parts including the battery power supply are enclosed in a small wooden jewel box.
Schematic
  • 1 × Jewel Box - unfinished wood 70mm High x 100mm Wide x 50mm Deep from Michael's
  • 1 × Digispark Digispark USB development board from Digistump
  • 1 × DC to DC Step Up Converter Search eBay for USB DC-DC boost converter
  • 1 × Micro servo 4.3G Buy several as the quality may be low
  • 1 × Lithium Polymer Battery 3.7V Canon NB-5L is a good choice.
View all 11 components
  • Jewel Box Calibration
    W4KRL04/30/2014 at 22:48 0 comments
    Good accuracy and linearity.
  • Electrical Schematic
    W4KRL04/28/2014 at 14:35 0 comments
  • Digispark Code
    W4KRL04/28/2014 at 14:32 0 comments
    // DS_ServoMeter
    // Karl Berger W4KRL
    // April 27, 2014
    // Released into the public domain
    // Converts a 0 to 5 Volt signal into a corresponding
    // position on a servo. The servo command is smoothed to
    // reduce jitter.
    // Uses SimpleServo in the DigiSpark library by
    // Benjamin Holt
    #include <SimpleServo.h>
    //create a servo object
    SimpleServo myservo;
    // The analog input signal is connected to P2
    // For pin mapping see:
    // http://digistump.com/wiki/digispark/tutorials/pinguide
    const int kAnalogInputPin = 1;
    // connect the servo signal line to P5
    const int kServoPin = 5;
    // Most servos are rated for 180 degree span but may be non-linear near
    // the extremes. A meter span of 120 degrees or less is more reliable.
    const int kScaleSpan = 120;
    // 4 samples provides good smoothing. More will slow the response.
    // Less will increase jitter.
    const int kSmoothingSamples = 4;
    //int smoothed_val = 0;
    // attach the servo to a pin then exercise it
    void setup(){
    myservo.attach(kServoPin);
    ExerciseServos();
    // read the analog signal, smooth it and convert it to a position
    // in degrees for display by the servo
    void loop(){
    // static variables retain their value between function calls
    static int smoothed_val = 0;
    // read the input voltage
    int val = analogRead(kAnalogInputPin); // this is pin P2
    // smooth the value by keeping a moving average
    smoothed_val = smoothed_val + ((val - smoothed_val) / kSmoothingSamples);
    // rescale val to the meter span
    val = map(smoothed_val, 0, 1023, 0, kScaleSpan);
    //command the servo to the corresponding position
    SetServo(val);
    //add some delay to let the servo seek its position
    delay(15);
    //adjust the motion of the servo to match the actual
    //position to the command
    void SetServo(int val)
    const int kServoZero = 20;
    const int kServoFullScale = 150;
    int pos = map(val, 0, kScaleSpan, kServoZero, kServoFullScale);
    myservo.write(pos);
    //Position at zero and full scale to check calibration
    void ExerciseServos(){
    const int kDwell = 1000;
    SetServo(0);
    delay(kDwell);
    SetServo(kScaleSpan);
    delay(kDwell);
    SetServo(0);
    delay(kDwell);
  • Expanded some build steps
    W4KRL04/28/2014 at 13:42 0 comments
    Added some detail to the construction and adjustment steps.
View all 4 project logs
  • 1
    Step 1
    Find a small wooden box with a lid that has a transparent panel in the lid. My box had a thin wooden panel so I had to carefully cut out one end to remove the panel. Remove all the hardware. Stain and finish the box. Cut a piece of plastic from a CD box to replace the wood panel. Reassemble.
  • 2
    Step 2
    Program the Digispark and temporarily connect the servo to test the software and servo. I had a batch of 5 identical servos. Two of them rotated contuously when the Digispark was reset. The other three worked fine. One of those three was very jittery. I thought they were cheap but buying five to get two working is not a bargain.
  • 3
    Step 3
    Test fit all the components in the box to find the best arrangement. Cut a piece of strip board 8 rows wide and up to about 25mm long that will fit flat on the floor of the box. The strip board will act as a bus to connect to the header. I placed the trace side up so I could solder directly to the traces. You may be able to prewire the board in a more conventional manner but then you would have a challenge soldering it to the header.
View all 9 instructions
