Gamepad
A project log for Dodo: 6502 Game System
Handheld Game System featuring the 6502
peter-noyesPeter Noyes 02/29/2016 at 21:502 Comments
A game system is not much fun without a gamepad so I prototyped up a quick one. I am now pretty close to being able to implement a game. Each button has its own little debounce circuit. The output of the buttons are tied high through a resistor, and are shorted when the switch closes. There is also a 0.1uF capacitor across each button. I am hoping the buttons work well enough as is without having to debounce in software.
I did an initial test of modifying my interrupt routine to test if the 'UP' button is depressed and if so to illuminate the LED. It worked!
Peter Noyes wrote 03/01/2016 at 01:01 point
Thanks!
Yann Guidon / YGDES wrote 02/29/2016 at 22:02 point
awesome :-)
