X_Axis_Drive.JPGclose up of the X Axis driveJPEG Image - 328.70 kB - 06/25/2016 at 22:30 |
PreppingToStartSomeMotion.JPGgot power supply, 12V 30Amp, probably more then I'll need for the amps, but we'll see. Got arduino and 3 stepper drives prepped for doing some dual axis manual motion.JPEG Image - 341.76 kB - 06/25/2016 at 22:30 |
SAM_0688.JPGjust a close up at the way the angle bracket is secured to the rail at the top of the gantryJPEG Image - 326.26 kB - 04/03/2016 at 01:24 |
SAM_0684.JPGJust a view of a hole I drilled through the MDF cross beam so that I could tighten up the screws and nuts holding the angle bracket on the gantry.JPEG Image - 329.97 kB - 04/03/2016 at 01:24 |
SAM_0685.JPGThis was the first screw access hole I drilled I was only able to get to one of the screws so I HAD to drill a second as picture in photo SAM_684JPEG Image - 331.98 kB - 04/03/2016 at 01:24 |
SAM_0682.JPGLatest full frontal viewJPEG Image - 337.80 kB - 04/03/2016 at 01:24 |
SAM_0683.JPGView showing the Z and X axis fully extended, but they do go beyond the working areaJPEG Image - 333.39 kB - 04/03/2016 at 01:24 |
SAM_0687.JPGSame idea as in SAM_0686 just a different type of deck angle bracket, it was too wide to use on the MDF at the top of the gantry.JPEG Image - 318.88 kB - 04/03/2016 at 01:24 |
SAM_0686.JPGJust a view of an angle bracket, normally used for decks to help hold / tighten this join between the MDF and 2 X 4JPEG Image - 331.13 kB - 04/03/2016 at 01:24 |
SAM_0680.JPGsomething of a top view shot, new base plate and one of the x axis slides in placeJPEG Image - 332.90 kB - 03/30/2016 at 00:16 |
SAM_0681.JPGbetter view of the left side where the z axis is controlled fromJPEG Image - 334.85 kB - 03/30/2016 at 00:16 |
JPEG Image - 341.28 kB - 03/04/2016 at 03:17 |
JPEG Image - 326.04 kB - 03/04/2016 at 03:17 |
JPEG Image - 343.69 kB - 03/04/2016 at 03:17 |
JPEG Image - 338.70 kB - 03/04/2016 at 03:17 |
JPEG Image - 341.90 kB - 03/04/2016 at 03:17 |
JPEG Image - 334.05 kB - 03/04/2016 at 03:17 |
JPEG Image - 323.55 kB - 03/04/2016 at 03:17 |
JPEG Image - 344.24 kB - 03/04/2016 at 03:17 |
