Record your best beats!
A project log for eXaDrums
Electronic drums for Linux
jeremyJeremy 03/10/2018 at 18:250 Comments
It was one of the first features I thought about when I started the project: a drum beat recorder.
Although it's now finished yet, there's now a "Record" button that lets your record drums as you play. When you stop recording, you can export what you've just played to an xml file:
The file contains the sounds that you used to record the track as well as all the triggers parameters. It is not a sound file, it just contains all the information that's needed to generate a sound track.
This is an important feature for eXaDrums, and you'll see another one pretty soon.
