Project plan (2)
A project log for eXaDrums
Electronic drums for Linux
jeremyJeremy 03/26/2016 at 20:110 Comments
Hi guys,
Here's a more detailed project plan (explanations after the image).
As you can see I'll be working on the GUI and the eXaDrums library at the same time. Since the GUI needs to use the SoundBank, KitManager, etc., that makes sense.
In the previous log, I also mentioned schematics and electronics. The two are obviously related, which explains the offset between blue and green rectangles. So, I'll be working on the new sensor's prototype first (schematic, then protoboard), then I'll finalize the ADC board, and finally, I'll make the actual new sensor's board.
As for the mechanics, it'll be addressed later, but I'll definitely start with an enclosure design for the drum module. Then, I'll start to draw some prototypes for the drums and cymbals.
Cheers.
