Clock IO Panel
A project log for easy-alarm-clock
Improvements for the ubiquitous alarm clock
Christoph TackChristoph Tack 01/11/2019 at 21:040 Comments
First layout version
IO panel with two times two concentric LED rings
Nothing to be really happy with.  This design is too large.  There are three rotary encoders with an internal switch.  The high switch actuation force of these switches prevents the panel from being used in a vertical position.  You would top over the clock when you push the switch of a rotary encoder.
The three rotary encoders will each be replaced by a push button switch.  There will be one encoder for general change of values.  You push the switch to select that functionality.  Using the rotary encoder you can then change the value at will.  This kind of user interface is used on the R&S RTO200O series oscilloscopes.
The double rings of WS2812B LEDs are also eating up too much space.  Let's replace these by LED bar graphs.
Second layout version
LED rings replaced by LED bar graph
The space consuming LED rings have been replaced by LED bar graphs.  Each one needs 10 inputs, so it will take some effort to get these routed properly.
The button for setting the brightness of the LED array and the light sensor are not related to alarm settings, so they have been removed from this module.  Functionality for setting LED array brightness should be physically located near the LED array, not on a separate IO panel.
So what's left?
It all doesn't look to well: all those bar graphs...  The rotary encoder is out of place.
Let's work out another idea...
Third layout version
Why not incorporate the LED bar graph functionality in the LED array?  We have plenty of pixels already there.  Both sides of the LED array can be flanked with buttons.  Alarm settings on the left, LED array settings on the right.  The pixel row next to the button can be used as a virtual LED bar graph.
The LED array "PCB" and the clock-io-panel have been merged into a single PCB.  This reduces cost and it will mechanical assembly easier.
Functionality overview at a glance, counter clockwise, starting at top left:
Alarm + LED array functionality merged into one IO panel.  Connectors & ICs not yet shown
In the middle you can find :
This clock-io-panel is bigger than the previous one, but 196x122mm will still fit on pretty much any night table.
