Housing
A project log for easy-alarm-clock
Improvements for the ubiquitous alarm clock
Christoph TackChristoph Tack 01/20/2019 at 11:500 Comments
Main housing
Material
Because of the sunrise simulation, the housing, or a least a major part of it must be translucent or transparent.  Translucent materials are preferred as the diffusion of the light will make the housing light up as a whole.  It's an option to use transparent materials for the housing and stick a translucent film onto it.
Corners
Manufacturers
Antenna enclosure
There's a chance that the electronics of the generate too much EM-noise, so that the antenna and receiver need to be placed in a separate housing.
A suitable housing is the Hammond 1593NBK (Farnell €2.75).
If you want to build a really cheap enclosure for your antenna with hot glue and some scrap piping, have a look here.
