New 10TFF layout
A project log for Yet Another (Discrete) Clock
I HAD to finally do this basic "exercice de style" in digital electronics, using some hundreds of transistors and diodes...
yann-guidon-ygdesYann Guidon / YGDES 05/18/2016 at 04:030 Comments
Learning from the mistakes of the first run of PCBs, here is the new layout.
I've had to play a bit with placement, for example the resistors : they are quite thin so the current placement is not a problem.
I have no idea when I'll be able to afford another PCB run... yes I'm that broke.
