The LEDs are in
A project log for Where's my Christmas Light?
Quickly identifying individual LEDs in a randomly distributed arrangement
danny-havenithDanny Havenith 01/30/2016 at 15:224 Comments
No LED identification without LEDs, so the first step in this project has been to order an LED string. After a ~20 day wait (shipping to Europe seems to take the longest), they arrived. Time to start coding.
First: let's see if my ws28811 driver still works for these strings...
Aaaand: no. Weird colors. But wait a minute, when I send pure red, green or blue, it quickly becomes clear that these strings don't accept their RGB values in G, R, B order as I'm used to with WS2811s, but in R, G, B order instead. So that's an easy fix and before the evening is over, we've got lights:
Danny Havenith wrote 01/30/2016 at 15:56 point
I've considered using the three channels in parallel, but first I'd like to get this to work on single channel and secondly, in a moving video, I'd like to keep all LEDs switched on to allow feature tracking over several frames.
Yann Guidon / YGDES wrote 01/30/2016 at 15:32 point
RBG order is the "normal" order but GRB is a hack in the design of the WS2812 integrated LED.
What kind of pattern do you intend to send ? I have examined similar situations and I'm curious to see what you have come up with :-)
Danny Havenith wrote 01/30/2016 at 15:42 point
I'm working on uploading the video for my first pattern. I'm still experimenting, but in essence it's a simple binary code, where all leds are turned on and off at the same time (for time reference), but LED colors alternate between blue and red (say, reds are zeros and blues are ones). This allows 2^n unique led patterns with n flashes of the LED string.
Yann Guidon / YGDES wrote 01/30/2016 at 15:48 point
It can be simpler and more efficient :-)
The binary code is indeed a good start, send 01010101010101010101
then 001100110011001100110011
then 000011110000111100001111
etc.
Now if you use R, G and B as different channels, you can reduce the number of steps to identifiy the position of each LED.
It will depend on the quality of the camera and its AGC to prevent saturation and color bleeding...
