• 1
    Step 1
    Get an SD memory card of at least 4GB.
  • 2
    Step 2
    Uncompress uElastix (elastix_arm) tarball file. The files "BOOT.tar.gz" and "rootfs.tar.gz" will be obtained.
  • 3
    Step 3
    Use any partitioning tool to create two partitions in the SD card. The first partition must be FAT type and its size of at least 16 MB. The second partition must be EXT3 type and its size of at least 3 GB. Example (supposing 'sdd' was asigned as the device for the SD card):
    [root@elx elastix-image]# fdisk -l /dev/sdd
    Disk /dev/sdd: 3965 MB, 3965190144 bytes
    122 heads, 62 sectors/track, 1023 cylinders, total 7744512 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disk identifier: 0xd048a4cb
    Device Boot Start End Blocks Id System
    /dev/sdd1 2048 67583 32768 e W95 FAT16 (LBA)
    /dev/sdd2 67584 7744511 3838464 83 Linux
      Note: When running fdisk in the partitioning process is recommended to set the type of the first partition with the option "t" and "e" for W95 FAT16 (LBA) (The option l will display a complete list). After this the process should be saved.
