VMU Zero V2 [coming soon]
Reviving the Dreamcast VMU
Raspberry Pi on Dreamcast VMU
Sega Dreamcast VMU is one of the perfect case for Raspberry Pi Zero. This is a build instruction how to make your own VMU Zero with OLED Display.
Original thread is found at sudomod:Dreamcast VMU Zero All-in-one.
Zip Archive - 118.17 kB - 03/18/2018 at 19:25
Download
  • Characterization of DCDC Boost
    satri36007/21/2018 at 07:53 0 comments
    Preface
    OLED requires 14V and VMU Zero generates it using Boost Converter. Conversion efficiency and output voltage ripple are evaluated.
    Test Setup
    Procedure
    1. Slide the Switch S1 to OFF position to disconnect the battery
    2. Attach the USB cable
    3. Display single color or white image on the OLED
    4. Measure I_in / V_in at R17 and I_out / V_out at 14V output
    5. [Test Case #1] Repeat 4 with varying the display image
    6. [Test Case #2] Slide S1 to ON and remover USB then Repeat 3-5
    Results
    OLED Power vs White Input Level
    Efficiency #1 - VBUS vs 14V Output
    Efficiency #2 - VBAT vs 14V Output
  • Characterization of Power Management
    satri36007/21/2018 at 05:51 0 comments
    Preface
    TI BQ24075 Li-Ion Battery Charger is used in the VMU Zero V1. This device also integrates the power path management to supply regulated power to the system even the battery is depleted or detached.
    Test Setup
    Procedure
    1. Slide the switch S1 to ON position to connect the battery
    2. Attach USB cable and fully charge the battery
    3. Probe VBAT and GPIO14 (TX) to monitor the system power status
    4. [Test Case #1] Leave the screen at emulator selector
      Remove charger and plot the discharging profile
    5. Charge the battery
    6. [Test Case #2] Load Super Mario on NES Emulator and leave at demo
      Remove the charger and plot the discharging profile
    7. Slide the switch S1 to OFF position to disconnect the battery
    8. Probe VBAT and CHG# to monitor the charging status
    9. [Test Case #3]  Leave the screen at emulator selector
      Slide the S1 to ON position and plot the charging profile
    Results
    Discharging Profile Case #1  - Idle at Emulator Selector
    Discharging Profile Case #2  - Super Mario Bros on NES Emulator
    It only lasts 20 minutes with the 150mAh battery. 500mAh battery will be considered for V2 design...
    Charging Profile Case #3 - Idle at Emulator Selector
    Charing time will look very similar regardless of the tasks on the Pi unless total input current exceeds the limit of 1.3A which is configured at I_LIM pin.
  • Characterization of Audio
    satri36007/07/2018 at 20:40 0 comments
    Preface
    VMU Zero is using the original piezo speaker in the VMU. Piezo actuator is essentially a capacitor and it requires higher voltage to drive.
    Test Setup
    Procedure
    1. Set volume as 100%
      amixer cset numid=1 -- 100%
    2. [Idle] Probe the GPIO18 directly at Pi output in idle state
    3. [Frequency Response] Probe V_in at R21 and V_out at LT3469 output
    4. Play pre-generated single tone wave file
      aplay sin_1khz_100.wav
    5. Measure the sound level at 2cm proximity using SoundMetrer X on iPhone
    6. Repeat step 3-5 with varying the frequency from 10Hz to 20kHz
    7. [THD] Probe V_in at R21 and V_out at LT34469 output
    8. Play pre-generated 1kHz wave file
    9. Record the sound at 20cm proximity using WaveSpectra on PC
    10. Repeat step 7-9 with varying the peak level of the wave from 10% to 100%
    Results
    Idle
    Continuous 8.4kHz oscillation was observed at PWM output when no audio. Amplitude was about 1.6V and DC offset was around 1.60V.
    Frequency Response - Individual
    Peak volume at 5kHz.
    Frequency Response - Sweep
    Narrow peak frequency response from 3kHz to 6kHz. Anything below 2kHz is significantly attenuated with -20dB.
    THD
    THD was almost 100% when the volume is 50% level because the PWM output was clipped above 50%. This resulted 3rd harmonic tone surpassing the fundamental of 1kHz at the speaker output.
    1kHz 50%
View all 3 project logs
  • 1
    PCB Assembly
    Tools
    Hot Plate
    JBC CD1-BB Soldering Station
    JBC C245-030 Conical Soldering Tip
    JBC C245-768 Chisel Soldering Tip
    ChipQuik SMD4300TF Tack Flux
    ChipQuik SMD4300SNL10 Solder Paste
    Senju ESC-M705-0.3 Solder Wire
    Fluke VT04 Thermal IR Camera
    Nikon SMZ Stereomicroscope
    Parts
    BOM File is available on GitHub
    All of the parts but LT3469 Piezo Driver are available from DigiKey at the time of this writing. You can buy samples of LT3469 directly from Linear Technology.
    Reflow
    Apply a bit of solder paste on the pads of U1, L1, L2, D3 and D4. Optionally for D1, D2, U2, U4 and CN2.
    Grab components with a tweezer and place them onto the PCB. Make sure to orient the U1 properly.
    Position the PCB on the hot plate over the thick tinfoil as a heat spreader.
    Cooking time! Turn on the hot plate and try to follow the recommended temperature profile of your solder paste.
    I heated it up to 180C in 3 minutes then 220C for the next 60s and hold for seconds. Thermal camera helped a lot to control the temperature. You should see solder paste turn shining silver when it starts melting. Do not heat too rapidly or parts would bounce up.
    Cool it down. Be careful, PCB is extremely hot.
    Assemble
    Install the rest of the SMT parts. Start with the U3 FPC connector then solder other parts on the top in order of increasing size.
    Finally install the CN2 battery connector on the bottom side. We will solder the piezo speaker from the VMU to CN1 later.
  • 2
    Software
    Install RetroPie
    Download RetroPie.
    curl -O -L https://github.com/RetroPie/RetroPie-Setup/releases/download/4.3/retropie-4.3-rpi1_zero.img.gz
    Unzip image.
    gunzip retropie-4.3-rpi1_zero.img.gz
    Insert an SD card and find the disk number. /dev/disk2 is assigned to my SD card but result would vary on the environment.
    diskutil list
    /dev/disk2 (internal, physical):
    Burn the SD card. Hit Ctrl-T to see the progress
    diskutil unmountDisk /dev/disk2
    sudo dd bs=1m if=./retropie-4.3-rpi1_zero.img of=/dev/rdisk2
    Create WiFi configuration file. Change the SSID and Password to match with your network
    tee /Volumes/boot/wpa_supplicant.conf << EOF
    network={
        ssid="SSID"
        psk="password"
        key_mgmt=WPA-PSK
    EOF
    Enable SSH.
    touch /Volumes/boot/ssh
     Boot the Pi Zero with the SD card then log on to it. The default password is raspberry.
    ssh pi@retropie.local
    Configure Pi
    The rest of the instructions would be performed on the Pi.
    Enable SPI.
    sudo raspi-config nonint do_spi 0
     Disable Overscan.
    sudo raspi-config nonint do_overscan 1
     Install FBCP.
    sudo apt-get install cmake
    git clone https://github.com/tasanakorn/rpi-fbcp
    cd rpi-fbcp/
    mkdir build
    cd build/
    cmake ..
    make
    sudo install fbcp /usr/local/bin/fbcp
     Register FBCP as a service. # DO THIS STEP ONLY ONCE #
    sudo sed -i "s/^exit 0/\/usr\/local\/bin\/fbcp \&\\nexit 0/g" /etc/rc.local
     Install FBTFT.
    sudo tee /etc/modules-load.d/fbtft.conf << EOF
    spi-bcm2835
    fbtft_device
    EOF
     Install SEPS525 driver.
    curl -O https://raw.githubusercontent.com/satri360/vmuzero_seps525/master/fb_seps525.ko
    sudo cp fb_seps525.ko /lib/modules/$(uname -r)/kernel/drivers/staging/fbtft/
    Configure FBTFT.
    sudo tee /etc/modprobe.d/fbtft.conf << EOF
    options fbtft_device custom name=fb_seps525 gpios=reset:24,dc:25 speed=8000000 rotate=180
    EOF
     Update module dependency.
    sudo depmod
    Install Retrogame.
    curl -O https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/master/retrogame.sh
    sudo bash retrogame.sh
     Select 3. PiGRRL Zero and reboot.
    SELECT 1-8: 3
    Downloading, installing retrogame...OK
    Downloading, installing retrogame.cfg...OK
    Performing other system configuration...OK
    REBOOT NOW? [y/N]y
     Configure Retrogame.
    sudo tee /boot/retrogame.cfg << EOF
    LEFT      17
    RIGHT     22
    DOWN      27
    UP        23
    Z          4  # 'A' button
    X         12  # 'B' button
    LEFTCTRL  16  # 'Select' button
    ENTER     26  # 'Start' button
    EOF
    Enable PWM Audio.
    sudo tee -a /boot/config.txt << EOF
    dtoverlay=pwm,pin=18,func=2
    EOF
     Set Maximum Volume.
  • 3
    Modifying VMU Case
    Tools
    Screw Driver
    Side Plier
    7mm Flat File
    XACT Knife
    Air Duster
    Disassemble VMU
    Strip down the VMU and keep everything but the PCB, coin cell and display.
    Try not to touch the piezo speaker to prevent fingerprints on the disc.
    Modify Case
    Use plier and flat file to make some changes to the case.
    Case Top
    Case Top Left
    Case Top Right
    Case Top Upper
    Case Bottom
    Case Lid
    Complete
View all 4 instructions
then.gms wrote 03/12/2020 at 03:12 point
anyone can supply this (pre assemble) I dont have skill for making this PCB board -
vmuzero_seps525 PCB
rubberdinghy wrote 08/06/2018 at 22:17 point
So where do you get the PCB exactly? Is it custom?
Wenting Zhang wrote 03/22/2018 at 22:01 point
It would be better if the screen refresh rate could be higher...
Jeremy g. wrote 03/19/2018 at 22:01 point
Epic! I have to make one now..
