How to build an extension pipe to shower 100% safe
How to build an extension pipe to shower 100% safe.
using materials with fair price found in house building materials.
Most water extenders for electric showers do not meet the safety standards ((are made of aluminum, iron conductive material electricity) and plastic low mechanical strength and inadquado length)
.or pays or contributes to study the paypal account josepedrofederal@yahoo.com.br
  • 1 × PVC pipe for water diameter 20 mm, high mechanical resistance and electrical insulation. pipe with quick fitting and connection LEDs and Accessories / Light Emitting Diodes (LEDs)
  • 1 × 20mm pvc glove with a smooth side and one screw
  • 1 × 20 mm suit with smooth and another part with external thread
  • 1 × Teflon tape
  • 1 × saw blade
View all 5 project logs
  • 1
    Step 1
    Measure the wall up shower drain (eg 30 cm) cutting the tube bar in size and sand the two extremities and then a dab of glue on the sleeve and tube and cencaixe the glove, right after pass glue adapter and the other end of the tube and fit both.
View all instructions
