Brushed DC Servo Drive
Back to overview
Low cost PID servo drive for small CNC machinery
David wrote 04/22/2016 at 20:39 point
wanted to know what you used to program the mcu and upload
ottoragam wrote 04/22/2016 at 22:09 point
I used an Stk500, but you can get any AVR programmer that does the ISP protocol, and connect it tho the 2x3 header present on the board. Hope that helps!
David wrote 04/23/2016 at 06:57 point
well i tried using a arduino as isp uplodaing hex with avrdudess
what were the fuse and lock bit settings
David wrote 03/31/2016 at 21:33 point
the boards just came in. Now to make a reflow oven and then ill test out the drivers
ottoragam wrote 03/31/2016 at 21:35 point
That's super awesome! Did you modify the design in the end?
David wrote 02/17/2016 at 06:05 point
Thanks
David wrote 02/17/2016 at 05:51 point
I would Like to Build one any istructions
ottoragam wrote 02/17/2016 at 06:02 point
I replied to your other message, Please check the files at my github repository.
