PCB Updates
A project log for Modular Teensy MIDI Controller
A modular take to a midi controller, using the Teensy LC.
max-litruv-boonzaayerMax Litruv Boonzaayer 04/17/2018 at 14:360 Comments
Going through a couple redesigns and commissions later, I've decided to make a modular device, multiplexing rotary encoders, buttons and whatever else, made with a configurator (wip) to generate the setup for the teensy to read (might just use serial + the eeprom instead of reprogramming..)
https://litruv.com/knobber/ if you want to have a bit of a gander what I've got going.
Commission for/u/sluggybear
Front of the new board
(Just noticed that screw hole being off - fixed already~)
More to come soon enough.
