Modules Being Created
04/17/2018 at 17:42 • 0 commentsRotary Encoder made!
PCB Updates
04/17/2018 at 14:36 • 0 commentsGoing through a couple redesigns and commissions later, I've decided to make a modular device, multiplexing rotary encoders, buttons and whatever else, made with a configurator (wip) to generate the setup for the teensy to read (might just use serial + the eeprom instead of reprogramming..)
https://litruv.com/knobber/ if you want to have a bit of a gander what I've got going.
Commission for/u/sluggybear
(Just noticed that screw hole being off - fixed already~) More to come soon enough.
