Back up to date
A project log for Raspberry Pi Zero LiPoly board
An add-on to the Pi Zero that charges a LiPoly battery when the Pi is using external power, and powers the Pi when not.
duane-bensonDuane Benson 05/12/2016 at 07:390 Comments
I've skipped a few logs. Since ,my last, I built up a V1.2 (I called them V2 in my earlier log) board. It worked, with a few mods, but I wanted a bit more flexibility with the I/O that I used, and some additional test points. That resulted in V1.3, which worked well, but needed a mod wire on the battery on/off indicator LED.
A V1.4 is now on the way that has that mod and an added set of direct battery pins to drive my dual motor drivers that I've since designed.
