First board design *almost* done
A project log for PoEPi: Pi Zero Power over Ethernet with PHY
It can power the Raspberry Pi Zero over Ethernet. The board also adds an Ethernet Phy to the Raspberry Pi Zero to give you full Ethernet
julienjulien 02/09/2016 at 12:040 Comments
The first board design is almost done. After having a discussion with someone about PoE I want to go back and double check the PoE design on the board. But if anything changes it will be minor.
The Layout and routing is finished and the good news is that there is lots of room left for custom applications. We will be building a couple custom applications for this board as examples of what can be done with PoE.
I am looking for suggestions!
