Audio PoEPi Finished
A project log for PoEPi: Pi Zero Power over Ethernet with PHY
It can power the Raspberry Pi Zero over Ethernet. The board also adds an Ethernet Phy to the Raspberry Pi Zero to give you full Ethernet
julienjulien 02/16/2016 at 11:541 Comment
Early in the project I mentioned that I would be making a couple variations of PoEPi so that other people can get an idea of how to make there own. While I sit and wait for my boards to come in 7 - 32 days (its always 32 days for some reason) I have created another version of the PoePi.
This version is a speaker amplifier. It uses the PiZeros Audio capabilities routed through a GPIO to make a speaker amplifier. This way you can make your own PA system or an excessive audio system where each speaker can also be an audio server.
Check out the details on the project page. I have also started a project log for this project on my blog OpenFET.
I am buy no means a good Audio engineer so it would be great if someone could give me some feedback on my design. I will wait until the other boards come back before ordering these ones.
One of the things I am known for is very very bad art and bad spelling. I wanted a cool logo for this project and had to use every ounce of creativity I had to come up with one. In the bottom right hand corner of the board you will notice the fun PoEPi logo. It was supposed to be a smiling RJ45 connector but it just looks evil.
vincent wrote 02/01/2019 at 09:31 point
did you get this board up and running?
