How to Remap Audio with .dts
A project log for PoEPi: Pi Zero Power over Ethernet with PHY
It can power the Raspberry Pi Zero over Ethernet. The board also adds an Ethernet Phy to the Raspberry Pi Zero to give you full Ethernet
julienjulien 02/23/2016 at 09:400 Comments
Device tree worked used to always scare me but once you have done enough of it on the BBB its pretty straight forward. The documentation for the device tree remapping is finished. The doc is on the git wiki. I’m still a little upset that the git wiki formatting hasn’t been made to match actual wiki syntax.
Check it out here
Take a look and let me know if anything is off. Maybe ill make a script to automate this... but then again no one would learn anything.
