Weave Integration, hardware update
A project log for wifiRC
Anything goes digital transition for radio control appliances. Like HDTV, but for RC projects
Blake W. FordBlake W. Ford 03/31/2016 at 22:480 Comments
Current changes to the codebase include the addition of a Json command format. This matches at least part of the layout from the upcoming Brillo/Weave standards as best I can gather given the limited information available.
"name": "_wifiRC._set",
"parameters": {
"_direction": "0",
"_directionString": "IDLE",
"_magnitude": "0",
"_lights": "false",
"_gear": "0"
I also put on order and Arduino Protoshield, some relays, mosfets and resistors to build a single integrated board for the vehicle hardware. All of that will eventually be coupled with an Edison Arduino breakout and the source ported accordingly.
