Updating and creating docs
A project log for LiFePO4wered/Pi
LiFePO4 battery / UPS / power manager for Raspberry Pi
patrick-van-oosterwijckPatrick Van Oosterwijck 02/12/2016 at 20:560 Comments
Well a nasty cold/flu/whatever sure has been holding up progress on this. :-(
But I've just managed to test the install script on a clean Raspbian Jessie install and made changes to make things work better, plus there is now a decent README for the software package. Check it out at https://github.com/xorbit/LiFePO4wered-Pi.
Installing is basically a simple git clone / run build script / run install script sequence.
More docs are to come on internal registers etc.
The time lapse box did a good job capturing some unfortunately lousy pictures. :-/ It seems outgassing from gluing the clear window had caused some serious surface etching, making everything look weird and washed out.
There also seems to be a remarkable amount of traffic on the path where I had installed the box, accidentally capturing no less than 4 people in a total of 54 pictures! :-) Maybe find another spot after I find a way to clear up the window.
