Load tests LiFePO4wered/Pi3
A project log for LiFePO4wered/Pi
LiFePO4 battery / UPS / power manager for Raspberry Pi
patrick-van-oosterwijckPatrick Van Oosterwijck 12/13/2016 at 23:240 Comments
I did a couple more load tests with the LiFePO4wered/Pi3, the variant that uses the #LiFePO4wered/18650 as a charging base (and should be for sale very soon now). A lot of people seem to have applications where they want to use a Pi 3, use the LiFePO4wered/Pi as UPS, and also plug in a USB flash drive. Since flash drives are power hogs, I decided I should test some scenarios with a flash drive plugged in. So here are a couple of tests I did, with the LiFePO4wered/Pi3 charging from a 2A USB charger:
I'm quite happy with these results. Systems running at 100% CPU continuously are very unusual. Using a WiFi USB dongle on a Pi 3 is very unlikely as well (unless breaking that silly flip chip without any protective packaging is common, which wouldn't be too surprising). I'm certain the on-board WiFi uses less power than a WiFi USB dongle, so I'm pretty confident that scenario with the CPU @ 100% will work as well. I really should get myself another Pi 3 some time so I can test it.
