adding the tft
A project log for PiBoy-Zero
yet another portable console! ;-) roughly the size of a gameboy micro, with a 2.2" display
johschneiderJohSchneider 02/10/2016 at 18:070 Comments
addingthe TM022HDH26 spi display and a raspberry to the mix
of battery + powerboost + softpower-circuit
the breakoutboard is a cheapish chinese import, with a slightly different wiring for the backlight - the important part: the display is the same as in adafruits 2.2" pitft hat (and their 2.2" spi display breakout).
hence it is easy to get it up and running following these instructions:
https://learn.adafruit.com/adafruit-2-2-pitft-hat-320-240-primary-display-for-raspberry-pi/easy-install
