So the long awaited PiAngle Mount is here and you can get it on Shapeways if you like. Located here: http://shpws.me/MFcn
Requires these screws: http://www.mcmaster.com/#99397a180/=142ixlp
A project log for PiAngle Zero - Not just another Pi Zero USB Hub
A plug-n-play 4 port USB hub for the Pi Zero - No soldering required! Also provides a power source for the Pi
