Found a great article by N5ESE on T/R switching a receiver and transmitter without the use of a relay, this is something I will try to incorporate into my design, rather than needing 2 relays for switching. I will also let the microcontroller have full control of TX & RX power, and as I have said before, sidetone; that's 4 output pins I need...
