Moxon calculations
A project log for The Australia Project
Somebody must be able to hear a Pi Zero on the other side of the world!
Jenny ListJenny List 02/05/2016 at 09:420 Comments
There are loads of online Moxon dimension calculators, a quick Google search should find you one. The one I used was http://ab1jx.1apps.com/ham/calcs/moxon/index.html. They provide this diagram showing the Moxon antenna dimensions, the calculated values for the 20m WSPR frequency 14.0956MHz are below.
A: 7.7594 M
B: 1.1882 M
C: 0.1892 M
D: 1.4385 M
E: 2.8159 M
For my Moxon I intend to follow a well-trodden path of making a support in the form of a large X supporting each corner.
