As promised, this is the final layout. Check the files area for the updated C3 version.
A project log for Hakko revenge
Building a smarter, smaller and more user friendly soldering station
Thanks Marius! Would it be possible for you to provide gerber files? Also, I cannot find the updated C3 version of layout in the files, there seems to be only old one uploaded on 06/06
Yes. I just updated the old one. It must have kept the same date but it is a newer file. I also uploaded a zip archive with the gerbers. Have fun recreating it and send a picture.
Thank you! I will for sure post pictures once I recreate the board :) Could you also share .bin files for flashing? I haven't used IAR Embedded Workbench myself.
I uploaded the build tree. I'm not 100% sure you will be able to flash it with something else, but it's worth trying.
