bluLogi BraiN
Make your grill smart with ble enabled multi probe grilling grate temperature sensors and tie that data to an app to make you an expert.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The BraiN's intent is to make your grill smart. Via precise multi zone temperature sensing of the cooking surface (the grill grate), the BraiN pairs via Bluetooth with an app that walks even the most novice user through perfect grilling results every time. Why measure the grate when my grill has a thermometer in the dome? Simple. You cook on the grate when grilling, not in mid air!
