USB OTG and a linux kernel can be used to serve up disk images over USB Mass Storage, removing the tedious task of finding a suitably sized, unused flash drive and imaging it to boot your target. Just download the disk images (img or iso) to your universal boot device(maybe even from the device), and select which to serve from the lcd/dpad menu or change the default startup image, and boot to your image.
