Dear friends and followers of WLANThermo (which should be named WIFIThermo in the english world but we are Germans, you know... :D),
We proudly announce the release of the new version 2.3.1-0 after many long days and nights of coding, debugging, testing, building and beerdrinking. Ok, the proud got damped a bit after we realized, 2.3.1-0 had a glitch in the final building-process! So we spent another long saturday in debugging, coding, testing, building (well and coffee this time ) and last night, we made it and released the hopefully working 2.3.1-1!
Our focus with this release was adding some features, fixing bugs and increasing usability.
Here is a translation of the original changelogs:
Changelog 2.3.1-0
ADD: Alarm quittieren ueber das Display
Acknowledge Alams with touchscreen
ADD: Nextion Display ueber Terminal flashen möglich
Flash firmware of display via terminal
ADD: Ordner /var/www/conf ist jetzt im geschuetzten Bereich
Put configuration file in password-protected area
ADD: Softwarelizenz GPL
Include GPL
ADD: Pitmaster Solltemperatureingabe jetzt mit einer Nachkommastelle (Armin's Onseneifunktion)
Pitmastertemperature now with 1 decimal place (i skip the Osenegg-portion)
ADD: GPIO fuer IO und IOPWM waehlbar zwischen GPIO4 (12V Signal) und GPIO2 (3,3V Signal)
Selectable GPIO for IO and IOPWM (result:switchable IO-Signal from 3,3V to 12V)
ADD: GUI-Update gibt Informationen ueber den laufenden Installationsstatus aus
Updateinformation in GUI during onlineupdate - Not just wait but you can see, what Raspi is doing
ADD: Zero Cut Funktion fuer Luefter
Zero cut function for fan
FIX: IP Adresse wird in der wifi.php nicht angezeigt
No IP-Adress shown in GUI
FIX: index.php Webcambilder werden nicht angezeigt/ imagemagick wird Installiert (Fehlt unter Jessie)
Missing webcam-pictures
FIX: Display-Update V1.0, Neue Tastaturen, Sonderzeichen, Alarmquittierung, Fehlerbereinigung, Speicheroptimierung
Nextion Display Firmwar version 1.o, new keyboards,
FIX: Herunterfahren und Neustart mittels Display funktioniert
Restart and shotdown via Display works now
FIX: Es lassen sich jetzt mehrere WLANS ueber das Display konfigurieren
Configure multiple accesspoints with touchscreen
FIX: WIFI Script language.d Problem geloest.
language problem solved in wifi-script
FIX: Info Seite angepasst
changed info-page
FIX: Pitmaster beim Neustart
pitmasterproblem (always on) after restart
FIX: Duty Cycle min bei IOPWM
minimum dutycycle.
Changelog 2.3.1-1
FIX: GUI-Update gibt Informationen ueber den laufenden Installationsstatus aus
Now really info during update
FIX: Fehler in der function.php - Neue configeinträge wurden nicht uebernommen
missing values in configuration
FIX: Fehlerhafte Versionskennzeichnung in der header.php behoben
wrong version-encoding
FIX: DOS-Umbrüche in /usr/bin/raspiwebcam.sh beseitigt
windows formatting of a shellscriptUpdate is available via onlineupdate. If you build a new thermometer, just download the software as described in the documentation and you will be on 2.3.1-1!
I hope you enjoy it and feedback is always welcome!
Cheers
Armin
armin
