New Release 2.5.2-0 Bilingual DE_EN
A project log for BBQ WLAN Thermometer
8-channel (BBQ)-Thermometer hooked to your WLAN
arminarmin 12/02/2016 at 18:370 Comments
Hi friends,
the latest release supports English and German user interface!
We also incorporated Celsius/Fahrenheit-Switch and lots of other fixes and improvements.
In case of a failure of the online-update, please ssh to your decvice and do the following:
wget https://github.com/WLANThermo/WLANThermo_v2/raw/master/ressources/fix_installation.sh
sudo bash ./fix_installation.sh
After that, you can access webinterface and perform a normal update.
Changelog since last projectlog:
wlanthermo (2.5.2-0) stable; urgency=medium
  * FIX: start update as an extra service
 -- Bjoern Schrader <grillsportverein@bjoern-schrader.de>  Tue, 29 Nov 2016 22:30:00 +0100
wlanthermo (2.5.1-0) stable; urgency=medium
  * FIX: added missing probe documentation
  * FIX: Pitmaster: Reversed fan control doesn´t work
  * FIX: max and min alerts weren´t handled as float
  * FIX: display stops working on special chars in channel name
  * FIX: wrong names in probe reports
  * FIX: restore broken updates
  * CHANGE: remove superfluous decimals from values
 -- Bjoern Schrader <grillsportverein@bjoern-schrader.de>  Tue, 29 Nov 2016 08:44:00 +0100
wlanthermo (2.5.0-0) stable; urgency=medium
  * CHANGE: changed startup from SysV-init to systemd units
  * CHANGE: moved sudoers entries to seperate file
  * CHANGE: i18n of the source code
  * CHANGE: new display HMI version with icons
  * CHANGE: split alert messages to push/ telegram/ app
  * CHANGE: changed valid adc values from x > 60 to 15 < x < 4080
  * CHANGE: Nextion HMI Version 2.0
  * FIX: Poweroff on shutdown
  * FIX: Handle configuration file as UTF-8
  * ADD: probe documentation in Markdown format
  * ADD: function to recalibrate the NEXTION touchscreen
  * ADD: translation to english
  * ADD: temperature unit selectable between celsius and fahrenheit
  * ADD: probe type iGrill2
  * ADD: probe type ThermoWorks
  * ADD: probe type ET-73
  * ADD: probe type Perfektion
  * ADD: probe type ET-735
  * ADD: probe type ODC
  * ADD: probe type Santos
  * ADD: probe type SmokeMAX
  * ADD: probe type Weber_6743
 -- Bjoern Schrader <grillsportverein@bjoern-schrader.de>  Mon, 21 Nov 2016 14:10:00 +0100
wlanthermo (2.4.0-0) stable; urgency=medium
  * ADD: WLAN Reconnect über HMI
  * ADD: °C hinter den Temperaturen auf dem Display
  * ADD: Senden einer Testnachricht
  * ADD: Senden einer Pushnachricht
  * ADD: Solltemperatur mitloggen
  * ADD: Größere Plotgrößen
  * ADD: ZeroConf Dienstekonfiguration
  * FIX: GPL-Info in info.php
  * FIX: Neue configeinträge wurden nicht uebernommen
  * FIX: Shutdown der V3 über Button funktioniert nicht
  * FIX: Display - Sleepmodus bei Shutdown über Web-GUI
  * FIX: pit_man wurde nicht ausgewertet
  * FIX: HMI Version 1.8
  * FIX: Datenübertragung Display nach Wakeup korrigiert
  * FIX: PID Regelalgorithmus verbessert
  * FIX: Fehler bei KTYPE an Hardware > v1 behoben
  * FIX: Umlaute im Kanalnamen werden angezeigt
  * FIX: Neue Sensorparameter
  * FIX: Nextion-Display reagiert nicht korrekt auf Shutdown
  * FIX: Upload für Nextion-Display an neue Firmware angepasst
  * CHANGE: Medianfilter angepasst
  * CHANGE: Schleifenzeit der Messchleife korrigiert
  * CHANGE: Auslesen der Konfiguration in der Messchleife
  * CHANGE: Pitmaster: Anti-Windup II implementiert
  * CHANGE: Mehr Sonderzeichen und längere Passphraser für WLAN-Passphrase
  * CHANGE: Energiesparmodus für WLAN-Adapter deaktiviert
  * CHANGE: Nextion-Display per Default konfiguriert und aktiviert
-- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Sat, 16 July 2016 14:45:00 +0200
Enjoy!
Cheers
Armin
