Particle-Pebble Gate Jedi
Force to Pebble to Android to Cloud to Photon to TIP120 opens Gate
Having discovered several spare Midichlorians in my liquor cabinet, I trained and applied them to opening a large cumbersome gate. The FORCE motion travels through my inner what-nots and is translated by the Pebble Classic accelerometer toggling a command sent to the (Particle) Cloud (City) which returns to the Particle Photon triggering a TIP120 to fire a button on an existing RF transceiver.
May the ridiculous hand gestures be with you, always.
That time when --
  • 1 × Particle Photon
  • 1 × Pebble Classic
  • 1 × 7085 5V Step Down Transistor ESD and TVS Suppressors / ESD and Transient Voltage Suppression (TVS) Diodes and Arrays
  • 1 × 2.2K Resistor
  • 1 × TIP120 Discrete Semiconductors / Power Transistors and MOSFETs
View all 8 components
  • Fritz
    Vije Miller02/06/2016 at 02:33 0 comments
  • Pebble.js APP
    Vije Miller02/06/2016 at 02:12 0 comments
    // Gate Jedi Peddle APP (Version 1.3) @TVMiller
    // Pebble Blink APP @Jack-Dangerfield
    var Accel = require('ui/accel');
    Accel.init();
    var UI = require('ui');
    var ajax = require('ajax');
    var Vector2 = require('vector2');
    // Create Window
    var main_window = new UI.Window();
    // Open Button and Display
    var txtOnLabel = new UI.Text({
        position: new Vector2(0, 50),
        size: new Vector2(144, 30),
        font: 'Gothic 28 Bold',
        text: 'GATE JEDI',
        textAlign: 'center',
        color: 'white'
    // Display Main Window
    main_window.backgroundColor('black');
    main_window.add(txtOnLabel);
    main_window.show();
    // URL To Particle Cloud
    function Toggle(function_name,function_value){
      var URL = 'https://api.particle.io/v1/devices/XXDEVICEIDXX/' + function_name +'?access_token=XXTOKENXX';
      ajax(
          url: URL,
          method: 'post',
          type: 'json',
          data: { "args": function_value}
    // Accelerometer Poll and Function (Default 100Hz 25)
    Accel.on('data', function(e) {
      console.log(e.accel.x);
      if (e.accel.x > 900) {
        console.log(e.accel.y);
          if (e.accel.y > 900) {
      Toggle('gate','open');
    // Button Function and Photon Parameters
    main_window.on('click', 'up', function() {
  • Photon Code
    Vije Miller02/06/2016 at 02:07 0 comments
    // Gate Jedi (Version 1.3) @TVMiller
    int sig = D7;
    int command = 0;
    void setup() {
    pinMode(sig, OUTPUT);
    Spark.function("gate",gateJedi);
    digitalWrite(sig, LOW);
    void loop() {
    int gateJedi(String command) {
        if (command=="open") {
            digitalWrite(sig,HIGH);
            delay(3000);
            digitalWrite(sig,LOW);
            command = 0;
        else {
View all 3 project logs
