DATALOGGER w/ PT100 DRIVER
The logger has an OLED to show the status and to set the amount of measurements and the delay between them.
This project consists of an PT100 driver and an interface, which makes logging data simple and easy.
---------- V0.4 ----------
HOW IT WORKS
  • PT100 DRIVER
The PT100 is a resitor which changes its resitance depending on the temperature. At 0°C the PT100 has a resitance of 100 ohms. This resitor was placed in an bridge circuit and was calibrated to have an output of 0 volts, when the PT100 has a value of 100 ohms at 0 degrees.The maximum temperature should be 50°C. So the signal at 50 degrees was amplified to have an output of 5 volts which can be handled by the Arduino.
  • DATALOGGER INTERFACE SHIELD
The shield basicly constist of an OLED, two potentiometers and a button.
First the counter and the delay have to be set with the potentiometers. The counter sets the amount of measurements and the delay sets the time between each measurement.
New V0.4
After that you have to set which sensor value is going to be on the display while the logging-process.
A second button allows that.
After that the logging-processes is ready to start. Press the button!
The OLED indicates the process
OUTPUT EXAMPLE
The data is saved in a .log-file and can be easily converted to an excel-file
V1.0 (FUTURE)
  • Integrate a RTC module to log time and date
  • Optimize hardware
  • Change between Fahrenheit and Celsius
SCHEMATICS
PT100 DRIVER
  • 1 × Arduino Mega
  • 1 × Arduino Ethernet Shield with SD slot
  • 2 × PCB Electronic Components / Misc. Electronic Components
  • 1 × Button
  • 2 × Potentiometers
View all 9 components
View project log
