Servos and Thrust Section Installed
A project log for Active Stabilization Rocket System
Use control systems to control and stabilize a Amateur Rocket
Jeremy HallJeremy Hall 12/19/2016 at 03:460 Comments
A whole lot has happened since the last update. Here is what has happened in order
After all that I am basically done other than I am getting my fins in tomorrow and will be installing them.
I did test all the servos and they work perfectly and am just waiting to get everything finished now.
Should all be ready to launch shortly.
Godspeed,
-Jeremy Hall
My Wiring Harness
Bottom of the rocket:
Whole Rocket!:
