We have melted the metal, sir.
A project log for Active Stabilization Rocket System
Use control systems to control and stabilize a Amateur Rocket
jeremy-hallJeremy Hall 10/11/2016 at 22:080 Comments
After about two weeks I finally got the money to order myself a new soldering iron so I could finally put the board together. After about 30 minutes of soldering and making sure nothing shorted together I finally got it finished and plugged it in to test.
I used the ICSP header and loaded the Arduino Uno Bootloader onto it and it went perfectly.
After I continued on and uploaded my code for my rocket and as far as I can tell everything seems to be working fine. All lights are on and I can finally declare this board "flight ready!"
Other notes include upcoming changes:
Software:
Hardware:
Thank you for all the support!
Godspeed,
-Jeremy Hall
