More update videos
A project log for Toyota MR2 Turbo Engine Repair
I blew up my engine, and am going to remove it, take it apart and fix it. Not really a hack, but it is taking things apart and fixing them.
scott-sScott S 03/02/2016 at 23:170 Comments
Didn't actually take the hubs off in the end - removed the whole subframe instead
Removed the whole subframe by unbolting the shock top mounts, subframe bolts and control arms
Took the engine out by dropping it on the floor using an engine hoist, then lifting the car body off by the engine mounts, and dragging the engine out from underneath
Began dismantling the engine - need to inspect the crank to find any damaged bearings
