Removing Lettering from PVC Pipe
A project log for SoftEgg PVC + Spandex Trade Show Booth
How can my little company stand out from the crowd? How about a 20' tall spandex covered egg for a trade show booth?
t-b-trzepaczT. B. Trzepacz 04/29/2016 at 08:500 Comments
So, in order for this to look spiffy, I need to remove the lettering from the PVC pipe. I tried a bunch of solvents, and Laquer Thinner seemed to be the best.
I tried grinding the letters off, with some success, but it was hard to do it in a way that didn't accidentally leave deep pits in the pipe.
I've obtained a prodigious amount of lacquer thinner and a bit of roof gutter to dip the pipes in, so I'll update this as soon as I get around to that... I decided that dipping was the best because when I tried to rub it off with paper towels it seemed ineffective unless the surface was soaked with thinner first. So I might as well dunk the thing and then it will be easy, right? I just hope it doesn't do anything bad to the structural integrity of the PVC...
