Raspberry Pi Zero W / Commodore 64 Interface Board
Interface a Pi Zero directly to a Commodore 64 via User Port and IEC. Give your C64 a Linux upgrade.
Interface the Raspberry Pi Zero W to the Commodore 64 through the User Port.
Project goals:
1. Get a Linux shell prompt on your C64 through the Pi Zero's Console Pins.
2. Allow your C64 to access the Internet, USB, etc. wirelessly through the Pi Zero W.   In particular, ssh!
3. Provide Composite Video out from the Pi Zero that is usable directly on a Commodore monitor.
4. (Stretch Goal #1) If possible - use your C64's keyboard as the keyboard on the Pi Zero (through the serial port). Maybe through softwedge? (https://github.com/theatrus/softwedge)
5. (Stretch Goal #2) Add PWM audio output (along the lines of https://learn.adafruit.com/introducing-the-raspberry-pi-zero/audio-outputs)
6.  (Stretch Goal #3) Use the Pi Zero as a virtual Floppy Disk Drive through raspbiec (https://github.com/Flogistoni/raspbiec) (another option is ninepin, https://github.com/FozzTexx/ninepin)
  • 1 × Commodore 64
  • 1 × Raspberry Pi Zero W
  • 1 × 75HC245 For 5V / 3.3V translation
  • 1 × Custom board See GitHub
  • 1 × RCA Output Jack Sparkfun PRT-08631 or equivalent
View all 3 project logs
[deleted]
ajlitt wrote 09/18/2021 at 18:18 point
netatalk has been bridging AppleTalk to standard services for years.
Or do you mean LocalTalk, the RS422 twisted pair network? In which case look for a LocalTalk to Ethernet bridge on eBay.
ajlitt wrote 09/20/2021 at 20:57 point
Something like this: https://www.ebay.com/itm/384394800001
oshpark wrote 11/22/2017 at 05:39 point
Exciting project!
Andy Spencer wrote 04/16/2017 at 17:08 point
Great project! Nice work doing this . . . can't wait to see it working fully. :)
freefuel wrote 02/25/2016 at 02:33 point
can the Pi be placed on a cart board for the C64? I was thinking why not use a B+ or a Pi2 with their included Ethernet ports, that would make connecting to the internet easier!
Leif Bloomquist wrote 04/16/2017 at 14:37 point
Yes, that is exactly my idea.   With the Pi Zero W it is perfect for connecting to the internet wirelessly!
freefuel wrote 04/17/2017 at 00:42 point
plus on the cart port you may be able to interface a raspberry pi as cartridge to the C64. you may need some SRAM to do so and most defiantly will need level converters.
