Teensy 3.0 & 3.1 & 3.2 & 3.5 & 3.6
32 bit ARM-based boards for use with the Arduino IDE
this is a test
2nd line is another test
why can't I get any white space or text formatting to appear when this shows on the project's page?
View all 5 project logs
[deleted]
Paul Stoffregen wrote 07/01/2016 at 06:38 point
Would you believe I just tested the speed against a few other boards.  Here's the results.
https://github.com/01org/corelibs-arduino101/issues/166#issuecomment-229851730
Maybe this is some subtle bug in Teensy's Wire library, which this simple test couldn't reveal?  If you want me to investigate, you must post on the forum with complete code to reproduce the issue.
https://forum.pjrc.com/forums/4-Suggestions-amp-Bug-Reports
Paul Stoffregen wrote 07/01/2016 at 09:31 point
Those are from the i2c_t3 library.  The Wire lib has only defs for the standard rates, 100 kHz, 400 kHz and 1 MHz.  Just use i2c_t3 instead of Wire.  But if you *really* want to use those non-standard rates with Wire instead of i2c_t3, just edit the Wire.setClock() function with number for the speed you want to the I2C0_F register.  The very latest code (in 1.29-beta3) has new defines for the all the values with their actual division number (eg, I2C_F_DIV576) to make this easier.
