Teensy Audio Library Released
A project log for Teensy 3.0 & 3.1 & 3.2 & 3.5 & 3.6
32 bit ARM-based boards for use with the Arduino IDE
paul-stoffregenPaul Stoffregen 10/01/2014 at 20:580 Comments
Version 1.0, the first stable release, is now available.
http://www.pjrc.com/teensy/td_libs_Audio.html
Here's Hack-a-Day's coverage.
http://hackaday.com/2014/09/30/the-teensy-audio-library/
