Sunset lamp
A lamp the changes with the sun
replaced the inards of a basic lamp with 2 neopixel rings, and an esp8266
github repo for the arduino code:
https://github.com/Br3nda/thing-restful-rgb-lamp/blob/master/thing_wifi_lamp.ino
  • 1 × old lamp, that expects 5V usb power
  • 1 × esp8266
  • 2 × neopixel rings
View all 8 project logs
  • 1
    Step 1
    OpenHAB items:
    Switch Lamp_Switch "Lamp"
    String Lamp_Red  "Lamp Red"
    String Lamp_Green "Lamp Green"
    String Lamp_Blue "Lamp Blue"
    String Lamp_Brightness "Lamp Brightness"
    OpenHAB Rules
    rule "Turn Lamp off"
    when
        Item Lamp_Switch received command OFF
    then
        sendHttpGetRequest("http://10.1.1.83/lamp/OFF")
    end
    rule "Turn Lamp on"
    when
        Item Lamp_Switch received command ON
    then
        sendHttpGetRequest("http://10.1.1.83/lamp/ON")
    end
    rule "Change lamp brightness"
    when
        Item Lamp_Brightness received command
    then
        sendHttpGetRequest("http://10.1.1.83/lamp/brightness/" + receivedCommand)
        postUpdate(Lamp_Brightness, "")
    end
    rule "Change lamp red level"
    when
        Item Lamp_Red received command
    then
        sendHttpGetRequest("http://10.1.1.83/lamp/red/" + receivedCommand)
        postUpdate(Lamp_Red, "")
    end
    rule "Change lamp green level"
    when
        Item Lamp_Green received command
    then
        sendHttpGetRequest("http://10.1.1.83/lamp/green/" + receivedCommand)
        postUpdate(Lamp_Green, "")
    end
    rule "Change lamp blue level"
    when
        Item Lamp_Blue received command
    then
        sendHttpGetRequest("http://10.1.1.83/lamp/blue/" + receivedCommand)
        postUpdate(Lamp_Blue, "")
    end
    OpenHAB Sitemap
    sitemap lamp label="Lamp"
      Frame label="Lamp controls" icon="lamp" {
        Switch item=Lamp_Switch
        Switch item=Lamp_Brightness mappings=["DOWN"='-', "UP"='+']
        Switch item=Lamp_Red mappings=["DOWN"='-', "UP"='+']
        Switch item=Lamp_Green mappings=["DOWN"='-', "UP"='+']
        Switch item=Lamp_Blue mappings=["DOWN"='-', "UP"='+']
View all instructions
