RPiHeatingOilSensor.zip
The Oil Sensor (433mhz version & TCP versions).
Component List:
HC-SR04 Ultrasonic Sensor
DS18B20 Thermometer
Headers (male and female)
DuPont Connectors
Various Wiring
Component List for 433mhz Version:
Arduino Pro-Mini
RXB6 433Mhz SuperHet Receiver
FS1000A 433Mhz Transmitter
ZS-042 (DS3231) RTC
Component List for TCP version
ESP8266-ESP (07 or 12)
2x 3mm*4mm momentary switch
6x 10K (0806)resistors
1x 6.8K (0806) resistor
1x 3.3K (0806) resistor
1x 2n7000 mosfet
2x 10uF/106 (0806) capacitor
1x 100nf/104 (0806) capacitor
1x 1000uf electrolytic capacitor
1x AMS1117 3.3v
1x LM7805
1x 10uf electrolytic capacitor
1x 1uf electrolytic capacitor
1x 100K 1/4 watt resistor
1x 6.8K 1/4 watt resistor
PCB for etching
Zip Archive - 164.33 kB - 05/27/2016 at 10:54
Download
RPiHeatingInstall.zip
Beta version for Raspbian Jessie. Should work on most SPI based touch screens. Make sure to set up Jessie for your touchscreen and take note of pins needed.
sudo raspi-config
Select Advanced -> A3-Memory Split -> 16
Select Advanced -> Device Tree -> Yes
Download zip and place in /home/pi/
unzip RPiHeatingInstall.zip
sudo bash /home/pi/RPiHeatingInstall/setup.py
follow instructions.
Component list:
LED red x 1
LED green x 1
SPI touchscreen (this is mine https://www.raspberrypi.org/forums/viewtopic.php?f=64&t=48967 but should work with most SPI based touch screens)
Wifi adapter/ethernet cable
5v Relay Module
SD Card (4gb + should do)
Wires
dupont connectors
433mhz receiver + transmitter (optional)
Zip Archive - 184.75 kB - 05/27/2016 at 10:41
Download
Sources.md
List of sources for code and libraries
md - 2.70 kB - 04/25/2016 at 10:58
Download
Licence.txt
GPL v3.0
plain - 34.98 kB - 04/25/2016 at 10:58
Download
