Moving Forward
A project log for Digital Assistant & Networked Thermal Priter
A very simple web and voice interfaced thermal printer, assistant, and home automation controller.
jedilkemejedilkeme 05/18/2016 at 00:070 Comments
Monday May 16th-17th
Jasper install was a fail due to lack of space, ordered new 64gig SDcard to my surprise, when dd'ing the original 8gig to the new card, i found i couldnt expand the file system. One full day later i gave up and started from scratch, is moving quickly and i am updating the instructions and this "blog" as a whole. lesson learned, if you have a permanent or semi-permanent project dont use the NOOBS install, you cannot expand the file system later.
