Hackaday.io Hackaday.io
Sign up Log in
Share Your Feelings with the Sense HAT
Track how you feel against pressure, humidity and temperature using a Raspberry Pi Sense HAT.
zymbitZymbit
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
645 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
645
0
645
2
Team (1)
  • zymbitZymbit
Join this project's team
  • Get the Application
completed project
MISC
raspberry pi rpi Sense hat
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 02/09/2016 and last updated 6 years ago.
Description
Have you ever been curious as to how your environment impacts your health? If so, you’ll love this new application that mashes together 'how you feel' with physical sensor data from your immediate environment, allowing you to learn a bit more about how your body reacts to local conditions. Our bodies are the ultimate fusion of sensors, so why not collect this simple and powerful piece of data using your Raspberry Pi Sense Hat? Highlights: - Select an emotion using the joystick - Publish using Zymbit services - Mash together with RPi sensors (temperature, humidity, barometric pressure, acceleration, gyro, compass) - See 24-hour activity on time series charts
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Use your Hologram Nova to retrofit infrastructure. Setup the Hologram Nova using a Raspberry Pi to send (temperature) data to Ubidots
Project Owner Contributor
Hologram Nova to Ubidots
maria-carlina-hernandezMaria Carlina Hernandez
A different approach to tracking animals using Raspberry Pi 3, Texas Instruments Sensor Tag cc2650
Tracking without GPS
brenda-armourBrenda Armour
Raspberry Pi + Temp Sensor + RockBLOCK = :-)
Remote Controlled Weather Station
makersnakeMakersnake
A raspberry pi powered wearable cyberdeck with environmental readings and sensors using senseHAT
Wearable Cyberdeck
ian-madayIan Maday
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Share Your Feelings with the Sense HAT", please tell us the reason.
Send message
Remove Member
