Printer setup
A project log for Thermal Printer for shopping lists
An ESP-01 based thermal printer. Could be used for many things; I decided to create a shopping list printer with a simple web interface
christophChristoph 02/17/2016 at 09:360 Comments
Edit: the below is bullshit because I didn't remember that arduino's Serial converts integers to a human readable string. I'll try the initialization again with explicit casts...
My printer came with an already printed test page, which specified correct settings for heated points, heating time, and heating interval. I used those to initialize my printer after reset. Setting the code page and international character set didn't really do much, though. The printer will print configuration commands when they are sent, so this is what comes out after initialization:
The only thing that apparently worked as desired was the printer parameter adjustment. The first line looks a bit faint, whereas the following lines are reasonably crisp.
As special characters are not printed correctly even though I selected latin 1 I might have to create a conversion table from <what I think I want to print> to <what the printer thinks I want to print>.
Before I got this to work I tried adafruit's thermal printer library, which apparently doesn't like the ESP's Tx-only Serial1. After I changed the code to initialize the printer directly things started to work
