Now it does
A project log for Thermal Printer for shopping lists
An ESP-01 based thermal printer. Could be used for many things; I decided to create a shopping list printer with a simple web interface
christophChristoph 02/19/2016 at 12:002 Comments
First of all, after being pointed at the smartness of arduino's Serial.print(int) method, I'm now using write() to actually write out the escape sequences to configure the printer. It works now, so I can set the correct heating parameters and character code table.
Hardware
Here's a picture of the breadboard (including some unused components and inefficient wiring):
The red LED next to the buttons indicates that there is something on the list, but not printed yet. Pressing the print button (in this case the center button of those five) makes the device print the list and clear it. The LED is off again:
The printing quality seems to good. The first line is a bit fainter than the following ones, but well readable.
I had to replace my power supply (USB wall wart) with a "real" 5V/1.6A wall wart to get this printing quality. The USB one I used earlier, although rated for 2A, didn't supply enough current. I was advised in chat to place a short or low value resistor between D+ and D-, but simply replacing it was easier. I'll now clean up the code and put it on github.
Web interface
The web interface is dead simple. When the list is empty, it shows a text edit and an add button:
Items can be added by entering a name and clicking "Add". They appear on the list and the red LED is on (see above):
Checking the boxes and hitting delete does the obvious thing. Printign the list clears it, and the LED is off again.
deʃhipu wrote 02/19/2016 at 12:12 point
Very nice! What are you using to program the ESP? I checked your github repo, but it only contains a license and a readme...
Christoph wrote 02/19/2016 at 12:22 point
I'm programming the ESP with the arduino IDE, using an FT232
USB<->Serial adapter. Code is not up yet, but I hope to add it
today.
