Current project state
A project log for Sine-Wave LED Display
A display of 3 RGB LEDs with the PWM duty cycles of the blue and green channels controlled by out-of phase sine waves.
ph3enixhakrPh3enixHakr 02/10/2016 at 19:200 Comments
Digging this old project up becuase its time to put it on a perfboard, It was originally written for the Arduino Uno, so I need to port the .ino code in AVRC and manually take care of setting the Timer/PWM registers. Then I need tomeasure the power consumption and see if I can drop the clock speed any. Finally, I need to add a LDO regulator and set it up on perfboard with a 9V battery.
