More Sheet Metal
A project log for The ERB (Electric Rescue Bike)
An electric motorcycle designed around stringent requirements of weight, power and durability for use in deep woods rescue missions.
Adam CurtisAdam Curtis 02/18/2016 at 04:530 Comments
I'm still working on the side plates. These hold the batteries and act as protection for crashes. I have both battery sections done. I just need to finish up the lower sections that cover the gear reduction belt drive and the sprocket on the drive side. After that, and when I know where every bolt and screw is going, I'll machine the 1/4" 6061 Aluminum plate for the motor mounts.
I still need to make louvers or some kind of vent in these side plates to keep the controller cool.
